Guys,
After my long drive back to Crete I checked the engine oil level and surprisingly seemed to have used very little. I read the manual on how to check and can confirm that the levels on the dials seemed to match the book and the oil pressure sat around 4.5 when driving. The book says 3.5 but since it sat at 4.5 all the way through Europe I'm assuming this is okay?
Anyway, went out last night for a twenty minute spin - okay, to pose a bit by the beach - and then back to the house. When I switched off the engine and got out I immediately noticed a crackling noise coming from under the engine. I also thought the engine felt hot, although to be honest it's the first time I've opened the cowling after I've stopped.
The noise can best be described as getting some baconfoil and rubbing it together in your hands i.e. a scrunching, tinny, not nice noise. It went on for about ten minutes and then faded away to nothing. I came back to the car about 90 minutes later and the engine was still hot to touch - which really did concern me although I'm used to water cooled engines so am not sure if this should be a major concern.
I checked the dip stick and it seemed there was oil in the right place i.e. halfway between the spirals although since it was recently changed, filter etc. it was hard to tell.
I turned her over again this morning for a minute or two and again, once switched off, that scrunching baconfoil noise was evident. It only last a couple of minutes this time so is obviously related to the heat of the engine.
I'm worried I'm low on oil but the oil pressure gauge showed 3.5 when idling. I don't want to leave it running too long or take it out just in case it's really low on oil and I do some long term damage. Then again, if I assume that it is low on oil and it's not and over fill it then that's also not a good thing.
Has anyone some advice they can give me to get me out of this quandry?
Cheers,
Jon
Cheers,
Jon
