Sticking throttle pedal
TomsGT4
Just had a bit of an alarming moment. My brother in law was having a quick blast in my car and went to change gearand the throttle pedal jammed. After some quick thinking - he turned the ignition off and freed the pedal. When we got home wee had a look and the problem seems to be that there is a notch on the underside of the pedal that catches on the pedal stop. Has anyone come across this before? I think the easiest way to fix this is to remove said notch from the pedal and/or attach some sort of cover to the pedal stop.
Any other suggestions appreciated.
Tom
Well I know that this is a well known thing on 944's (I assume they share the same floorpan) if the car has been jacked up by a previous owner by the points immediately behind the front wheel arches that look like jacking points. This area is not strengthened and jacking up by these points can distort the floor pan and cause a sticking throttle as the throttle cable runs through that area which pulls on the cable and can prevent the throttle from being able to fully close off. These points are not jacking points - they are the points the shell sits onto the production jigs.
Scott ommitted to say that the fix is a solid piece of wood (to protect the carpet) and a couple of good thumps with a lump hammer, ask me how I know!
Mike
Hmm, don't think that's the problem. Think my brother in law just suffers from a heavy right foot.
