Steering wheels!
Jagermeister36
Is there a basic timeline for steering wheel options?
My 1980 turbo has the lozenge shaped wheel, I've previously owned a 1979 928 and it had a three spoke.
I've also seen pictures of later cars with the three spoke wheel.
Wondering if the wheel in mine is correct?
996TT_rennsport said:
Thanks, I’ve been told the four spoke was standard for MY81?
My MY 87 924S has the same looking wheel-down as the Sport Wheel in the specification
It does seem bit of a lottery as to which steering wheel you get on 924's. I suspect the lozenger wheel is the standard wheel then the 3 spoke (named as sports wheel in the parts listing) was an option. Having said that mine had a 964 lozenger wheel on it when I bought it - made lower down steering wheel issue even worse as it's bigger!!
I've done a bit of digging and it seems in MY81 there were two option codes for steering wheels on the 924;
416=380mm 3-spoke steering wheel
431=363mm 4-spoke H steering wheel
That implies that the 4 spoke being smaller is the Sports item-all I know is my Porsche Certificate of Authenticity states " Sports wheel " which coupled with manual steering & negative camber makes for parking hard work--fine once you'r rolling.
However since I replaced the steering shaft & the offside bottom ball joint ,steering is somewhat lighter
