Steering wheel shake
- Thread starter lmellman
oxford_hippo
had the same on ours - judder on braking,
we had foolishly not been out in the car for a long while - and the discs had been affected - think this si a known thing not to do with 993s - at least I now know it is thing not to do![
so new pads and discs all round - at least it now stops very very promptly, and am motivated to drive much more regularly.
Think some people have said you can get brake dics skimmed? is this feasible
Might this be a solution?[8|]
How calculated a risk is buying supposedly excellent condition discs off e Bay??
Though faffing of getting discs off, and to a machine shop, then re-fitted - is going to start getting close to just getting Indie to fit new pads / discs.
1 last thing - our aftermarket disc seem to show surface rust on the hub much, much more than OE ones, ( we can see this clearly as fronts were OE, and I managed to check witht he garage before he'd fitted OE to the reears so saved soem funds for something else.[
so if you are going to use aftermarket dics - suggest you paint the hubs before fitting ( sure someone here can suggest a good variety of paint type to use ( hammerite / engine painnt etc. etc.?.
[8|]
Mike M
I fell for this when I 1st bought the car 7 years ago, now with parking it up dry, touch wood never had the problem since!
John Maddox
clyde
ORIGINAL: JB 3.2
My local Independent (Auto 2000 in Bedford) offers a disc skimming option which is a lot cheaper than new discs and pads.
Is it worth getting them skimmed? I find I need new (Porsche) discs every second set of pads through wear as they're so soft. It's something to do with not as much chrome being used in the metal of the discs apparantly. Skimming them just takes them much closer to their minimum thickness.
JB 3.2
ORIGINAL: clyde
ORIGINAL: JB 3.2
It worked for me, as the MOT picked up corrosion on the inner face of the discs. It took a few miles for the old pads to bed in again but now they are better than before.
The skimming is a misleading term, its more like surface grinding and the discs stay on the car while its done.
I suspect that you are covering more miles than me, but a new pair of front discs for every two sets of pads would seem about right based on my everyday Audi wear rate, and is probably a better option for you.
"so if you are going to use aftermarket dics - suggest you paint the hubs before fitting" .....it's the part of the disc that bolts to the hub that needs painting on cheaper discs, not the hub itself.
