Stephenjk
I have a steering pump leak which appeared after my MOT, I assume they were a bit rough with the car
Anyway I'm hoping it is just the crush washers around the banjo bolt joint. The fluid does look like it is from banjo bolt and not hose above at least. The paper towel was only wet below the bolt.
I've ordered new washers any tips or anyone else had same issue?
