It's about time I sort out the biggest problem on my car, the steering!
The car goes where pointed, and turning right is fine either when rolling or accelerating. When rolling while turning left, fine again. However, when turning left, even slightly, while accelerating, there is an audible rattle and vibration through the steering wheel. From the drivers seat it seems to come from behind the steering wheel.
I mentioned the problem during a recent check at the Porsche centre and they noted that the steering wheel upper bearing was worn, the off side front wheel had play up and down (worn strut/wheel bearing), perished front shock bump stops, off side front bottom arm bush at rear perished, and rear shock bushes at bottom perishing.
Would any of this give me the steering symptoms mentioned? The car has previously been up on a ramp for a quick suspension check in regard to the noise and the mechanic said it was ok, so I've been worrying for months that I need a new steering rack!
Any advice would be greatly appreciated!
