Hi everyone
First time doing the static timing on my 356 so a few questions which are probably going to be very simple for those that have done this before!
The workshop manual says to set the static timing at 5o before top dead center, so with my crankshaft rotated to this position, should the middle of the rotor head line up with the indication mark on the distributor that is at about 5 O'clock?
Here's some photos of where I am up to
Crankshaft pulley showing TDC (in between letters O and T) and the indicating notch of where 5o before is (this was made before I owned the car, but measuring with a paper protractor it is pretty close to 5o)
Distributor rotor position when the crankshaft is rotated to 5o BTDC which shows that the middle of the rotor is not aligned with the alignment mark on the distributor itself
Distributor model and side view for reference
So my understanding is that with the crankshaft at 5o BTDC that I should loosen the horizontal bolt to the right of the bottom of the distributor and rotate the body until the indicator mark on the rim matches the center of the rotor arm, but that's the bit I'm not sure of so any advice much appreciated!
Many thanks, Alex
Many thanks, Alex
