Under the passenger seat (RHD) next to the DME. If you slide the seat all the way forwards, and lift it up, I think you can get to it reasonably easily. It seems to be standard practice to have a spare in the glove box. Mine failed a couple of weeks ago, while it was in for a service! Very convenient, as I didn't have to buy another spare.
Starting Problems
- Thread starter Richard_Hamilton
For a quick fix, you could look at the soldered conections in the DME and see if there are any hair-line cracks. Ususally you can only see these with a magnifying glass.
I understand this is the 'usual' reason for the DME failing, as it did on my son's SC and I found a hair-line crack, carefully resoldered it and Bob's your uncle - never been a problem since.
But keep a spare in the glove box anyway!
graham tompkins
Just seen this thread, certainly sounds like dme. You can check the dme by making a wire to link 30 to 87 and across to 87b . This will fire up the fuel pump which you should be able to hear running. As said,, always have a spare dme handy but the bridge is a get you out of jail bodge (don't leave it on after you stop as it makes the connection permenantly live)
Graham
Graham
graham tompkins
Assumed 3.2 as on this forum [8|] Oh well
chrishak
I think the OP's car is a 3.2, it's later that there's reference to an SCgraham tompkins said:Assumed 3.2 as on this forum [8|] Oh well
T911UK was referring to RICHOT89's post about his son's SC.graham tompkins said:Assumed 3.2 as on this forum [8|] Oh well
graham tompkins
Ahhh, must read posts properly..I will beat myself with a wet copy of PP
