Stale air
- Thread starter miltiadou
You need to run the system very regularly once it's sorted to keep things fresh. Don't run it for now if it smells 'cos the bugs can be harmful to your respiratory system!
Cheers,
Roddy
It contains an anti-bacterial and lemon-flavoured air freshener...
You'll need to set your blowers to 'recirculate' the air inside the cabin. Switch on the engine. Turn the aircon and blowers on. Then put the aerosol in the car (on the floor I think and away from anything that might get spoiled by moisture) and click it's lid down. It will then spray it's contents into the cabin and will be circulated through the air-con system.
You leave it for about ten minutes and you're done.[
http://www.coolitautomotive.com/contact%20us.htm
ORIGINAL: angry
Mine is not a a/c model but there are 2 filters in the scuttle panel behind/above the fuel tank that could need replacing.They are round and in each corner...they could be clogged/damp.
Dan
Dan,
Have you had this problem before and did changing the pollen filters make a difference?
Harry
