Spraying
- Thread starter Nouveau
Peter Empson
I may be wrong but I think bodyshops use a more flexible paint for these polyurethane parts, might be worth looking into. The other problem you might have is that it's a bit too cold to paint outside now and expect a good job unless you have a heater you can use.
morris944s2john
As allways, the final spraying is the last job and its the prep- sanding, filling, priming, then more sanding etc that makes the final spray coat look good. What colour is your car? in general the lighter the colour, the easier it is to get a good finish.
morris944s2john
That sounds either like poor preparation of the area to be sprayed (i.e. primer layer not absolutely smooth) or "orange peel" effect in the top coat. This can be caused by wrong temp conditions or paint mix or poor technique.
Peter Empson
The temp was definately an issue, technique too [ORIGINAL: morris944s2john
The wheels have lasted quite a few years so I can't complain. The badge panel was painted when it was freezing out and all I had was a useless convector in the garage [
sawood12
Hilux
T Cut can be too harsh.
If you want a good shine then use Mr Sheen on plastic bits.
