Spoiler fault - 992 GTS
Hi, I have a '22 GTS and have intermittent issues with the rear spoiler (not sure if it is also affecting the front spoiler as cannot see) - sometimes it stays up and sometimes does not rise, leading to different error messages. I waited two months for a service slot at Porsche Hatfield but the night before they called to tell me not to bring the car as they cannot repair it. Apparently it's a known issue and Porsche are trying to create a fix. They think it is linked to the materials inside the spoiler getting wet, but not an electronic fault. The fault is more common when it's raining, so I agree with the correlation here.
Does anyone else have this issue?
Nick
Nick, sorry to hear of your problem. Can I just check something- I wasn’t aware the GTS has a moving front spoiler, I’d understood that was only on the turbo?
Hi Nigel, I don’t actually know about the front to be honest. I assumed it had a front spoiler as it’s shown to have one on the info graphic inside the car when you manually override the spoiler settings. But I guess it might just be the same software and not actually have the moving parts. I had a quick look online but can’t see either way.
Nick
If you have an active rear spoiler, you should also have a complimenting retractable front splitter.
To confirm, extend the spoiler manually (weather dry! [;)]) via the PCM when stationary, then take a look at the front splitter. [:D]
Regards,
Clive
The front splitter/spoiler on the 992 GTS is not active, 100% sure on this.
Only 992 Turbo and Turbo S have active front splitter/spoiler.
Does anyone know whether Porsche have a fix for the spoiler retraction problem? My 2023 car has this issue
although the OPC doesn’t recognise it as a known problem and the intermittent nature makes resolution
difficult
I had this within 10 minutes of driving my new Turbo S off the dealer's forecourt.
See my thread about this posted over a year ago:
https://www.porscheclubgb.com/forum/tm.aspx?m=1131122
I appreciate the spoilers are very different on the GTS to my Turbo S but both have control units which your dealer should be able to change. Mine was done under warranty, otherwise the part would have cost about £1700. I hope you get yours fixed because the warning messages and alarms are very annoying.
Thanks for replying on this topic
I gather from the OPC this is an issue
they are well aware of!
Hi all, checkers did you get a resolution? My recently collected 992.1 GTS has developed this issue. Had it three months with no problems and in the last two weeks same issue twice, spoiler doesn’t deploy fully and then when I’ve stopped it’s stuck out. Will contact Reading OPC but if it’s a known issue it helps. Thanks
As I originally posted the spoiler deployment is often a consequence of issues with the actuator especially in wet weather. Whilst I have no experience of 992.2 cars both my .1 cars had this issue and were fixed under warranty
I have a GTS 4 targa 992.1 2024 car, in the heavy rain last week when I collected it the rear spoiler went up and I cannot work out how to put it back down. any advice?
You can manually deploy and return the spoiler to its original position using the PCM… Here is a link to explain how to do it.
If this doesn’t work, perhaps its a visit to the OPC .
I feel sure that spoiler issues are well known to the dealers…
The issue is well reported and usually self corrects well before you can get a
OPC to look at it. If you try the manual extension function take the spoiler to position 2 and then try to close.I’m
not recommending this but mine closed by having a friend gently press down on the spoiler whilst using the close function
Try driving on the motorway at the speed the wing goes up, be mindful of its over the limit, and then slow to a speed where the wing goes down. It may rectify itself that way.
Dan.
