speedo
- Thread starter robwright
Gavin944s2
my speedo needle flickers , it seems unbalanced .
How do i remove the clocks to change the unit or is it 1 cluster? I would like to take it out & repair or replace it, with similar etc
thanks
pauljmcnulty
Gavin944s2
craig2105
xenon
Gavin944s2
bingo, just what i needed to hear..exellent guys. many thanks to you xenon [ORIGINAL: xenon On the S2 it will invariably be the sender which is located on the nearside driveshaft output on the gearbox. It's electrical without a traditional, geared cable. The location means it is subject to lots of road dirt and spray. Remove the plugged in connector (secured by a wire retainer) and thoroughly clean the contacts and plug with alcohol or contact cleaner. Job done.
