Spark Plug change
Simon P
Hi, Anyone had similar problems to me when dealer is changing spark plugs on a 991.2? The bolts that hold the coil packs to the engine tend to seize inside the coil pack and the bolt heads break off! Porsche Centre wanted a huge amount of money to do the change so I went to a reputable indy who do the job by sacrificing the coil packs so they can access the bolts. Apparently the bolts are not greased when first installed and this is a common problem.
Hi, I had the same problem on my 2018 991.2 during the 4 year service. Two of the bolts were seized and they had to be drilled out and the affected coil packs replaced. Fortunately, this was covered by the Porsche extended warranty. From looking online I agree, this doesn't appear to be uncommon.
It's not only 991. 718s suffer with this as well. They also suffer with spark plugs seizing in the block.
Dan
Older car, similar problem
My 991 is under warranty and this excludes owner maintenance. However I think it would be negligent to not do some of the basics like lubricating hinges, locks etc.
I've been thinking recently that this should extend to other items under the car like lubricating sports exhaust linkages, turbo waste gate linkages, many exposed threads, nuts, bolts, pipe clamps and bleed nipples. Has anyone systematically gone through their car and done this?
I've done it on other vehicles and used various lubricants and Bilt Hamber Atom-Mac which is a spray-on water-bourne corrosion inhibitor.
My 991.2 c4 gts is currently at the opc for 8 year service and bolts are all seized, will challenge the charges planned as also have the extended warranty on Monday but also pending cost on a cracked cam cover. Only found this late on friday so again not clear if under warranty… interested to hear if anyone else has managed to challenge the opt and get covered by warranty?
