philholzer
Hi,
First post, but looking for some advice on my twin solex carbs. I bought a pair of second hand Solex 40 PII and have now rebuilt them several times! Spent a small fortune on replacement components, returning them back to factory spec. They have been apart so many times, I recon I could strip and re-assemble in less than 30 minutes.
There is little perceptible play in the in throttle shafts, a very small lip on the throats from the butterflies, but they appear to seal reasonably well. I have been through the entire ignition system and timing is all spot on. They've spent several hours in the ultrasonic cleaner. Last strip, I even removed the welch plugs to ensure all of the passages are clear.
The problem I am having is that I can not get the idle below 2500-3000 RPM. Normally this would be indicative of a vacuum leak. I have checked the flatness of the mounting flange, whilst not perfectly flat, they are not far off. During the last re-assembly I smeared a small amount of sealant on the gaskets to ensure there was no vacuum leak.
The only thing I haven't done yet is to set the float height, but I wanted the idle nearer 1000 RPM before doing this?
Any advice would be much appreciated. Not far off ditching them for a pair of brand new Webers!
Many thanks.
Phil
Many thanks.
Phil
