sloww 944
- Thread starter Dunc2047
robwright
pauljmcnulty
Ive just got my first porsche 944 and it feels very slow at pulling away not much power unless you rev it very hard could it be a mixture problem,
Need to know more. Is it a sixteen valve engine? Does it have the earlier bodywork without the later Turbo and S2 spoiler on the back and "bluff" front end? Could be a 944S, in which case that's the character of the engine.
ORIGINAL: Dunc2047
Hi all
Compared with what? All the other 944s you tested before buying this one, or compared with your previous car?
I'd get an air filter in there before you drive it again or you risk bits of dust or grit getting into the engine and scoring the bores which will kill your compression and leave you with an engine very down on power [
deafasapost
compared to my turbo diesel c4 citroen, it hasnt the torque low down the rev range but it makes up for it and more past 3.5-4k revs. tomorrow is dry and i'll be taking it to work, so i'll have a better idea tomorrow.
pauljmcnulty
took mine out for the first time last night for about 5 mins (twas pi55ing down!) and i went easy with the laughter pedal and thought at low revs (i'm talking 1200-1500 rpm btw), it seemed slow, esp for 200 odd hp and 3 litres. i took it on a nat speed limit lane which has a good straight for a little bit and gave it a bit more revs and gas. it aint slow!!
At the risk of hijacking the new guy's thread...sorry, we do this a lot! [
The S2 benefits from a chip, it smooths out the power curve. I don't know if mine is chipped, but there isn't any real difference as you hit higher revs. It's power all the way. UK luxes have an oval throttle cam, an ecnomy thing for the US market. This is easily changed to a rapid-response alternative, Porscheshop fit them at their open days for a very good price if you don't DIY.
Most 944s really benefit from a good service. How many times have we seen picture of rotor arms and dizzy caps that look so bad the car shouldn't run at all? Fuel filters are often not changed, leads are usually original. Tyre pressures make a huge difference to the handling, let alone a decent 4-wheel alignment or suspension overhaul.
My 944 is a 1992-3 on a x reg its a 944 lux think it must be an 8 valve from cold its much better then when warm just seams under powered but does go well when i get over 3000 revs, Think i might go a drive another 944 just to compare tho it just might me want to much out of an old car.
I have noticed then once the car as warmed up it does have a miss fire when you accelerate when you try to push the car..
Any advice is very welcome..
robwright
Highwayman
I'm planning on a new air filter tomorrow (oil & filter done by previous owner) and then fuel filter and ultrasonic injector clean over the coming weeks. Then I'll have to give one of these chips a try, as they sound like they provide a worthwhile improvement once the basics are sorted [8D].
Phil
alwigley
Get an air filter in there ASAP [
Ive an '83 and as above.
Also remember it should run on 98 or better fuel - Shell 99 works for me.
My experience would be airfilter dizzy and rotor arm. That should be a good start.
If the throttle cam has lever on it, swap it for a round one. This is the throttleresponse cam mentioned.
Where are you - there's probably someone local who can help.
I m in Leicester phone no below.
Enjoy a different motoring experience!
Mike
GlennS
Leaving aside some fiddled turbos, none of the stock 944s are THAT quick. That's not really the point of them, at least to me. They're an attractively shaped classic which is relatively easy to live with, handles well and is "fast enough" to have fun in. If I'd wanted ultimate performance for my money, it would have been better spent elsewhere.
Dunc2047's one does seem to be in need of some tender loving care. It would be hard to argue that a previous owner, who omitted to do the basics like fitting an air filter, gave the car the attention it deserves. A bit of sympathetic fettling might encourage some of his stray ponies to return to the herd but my basic advice would be not to set the performance expectations too high and to enjoy the car for what it is; a superb piece of 80's automotive design that's still a pleasure to drive and be seen in today.
Hilux
`scuse me?
Forget 0-60, thats for willy wavers and 17 year olds....................instead look at the 30mph incremental times on a standard turbo!
Having said that, the 944T standard 0-60 is still very impressive for its time.
Miss mine..........[&:]
sawood12
deafasapost
i took mine out properly for the first time today, i think the accelerator pedal with being heavier than i'm used to makes the car seem slower, but, it aint, no sireeeee [
it shifts enough and is more than enough on the power front on these roads.
a few years back, i had a minster engined rover, and that was very quick, but the chassis and brakes weren't upto the power, and neither was the front wheel drive. the 944 is a lovely car, built like a tank and is so planted.
after being in the 944 today i got into my C4 and it felt light, flimsy and like a 4wd!! funny isnt it how you get used to something and then climb into something else you've been familiar with and it feels alien. ahhh, cant wait til the morrow to clean and polish her, it sure does need it!! [
mr brightside
I'd take the lads' advice about your filter and HT components, you have to start at the bottom and work up.
Hilux
A 944T in standard trim (with a good torque curve - a lot have very odd torque curves - see Rick`s site!) will beat a Fezza 360, Carrera 2/4S, M3 etc etc etc through the gears when up and running believe me. Also the 944T is light in comparison to modern cars eg: the latest Golf Gti is no quicker than the original!
