chrisg
Morning All !
Since doing the belts over the winter/ spring I've now done ~ 1500 miles on the turbo. I've noticed since doing it that when first started up (particularly if cold) it will fire up and then miss just once/ slight hiccup then idle fine.
Similarly, if driving along (in any gear, more noticeable at slow speed) if u come off the throttle completely then boot it hard it will hesitate/ stutter for a fraction then it's fine. Regarding all other aspects of running, tickover, full or part throttle under load it pulls like a train and boosts well.
It's just from closed throttle.
As I'm currently using it as my daily driver I'm reluctant to start fiddling.
Thought I'd ask if any has any thoughts in addition to/ instead of:
1. Throttle position sensor - either faulty or needs adjusting
2. Slight boost leak, particularly from the J-boot - caused by pulling apart to do the belts
3. Slight boost leak from any other pipes whether IC or small boost pipes.
Any suggestions or recommendations gratefully received !
Yours
Chris
Yours
Chris
