Sick of sliding around
- Thread starter sawood12
TTM
Well-known member
ORIGINAL: edh
I don't think the Falkens come in 245/45/16?
Sadly not, as far as I've searched.
Neil Haughey
Peter Empson
ORIGINAL: Neil Haughey
Not so sure about the Toyo T1-R, TTM reported a bad experience with them and now I have been getting the same experience with them on the back of my 968. A step backwards from the excellent T1-S which itself is an old tyre now. R888 maybe but I can't see me fitting any of the other Toyo current offerings.
I'm a bit puzzled about these experiences with T1-R's, I've had something like 4 or 5 sets and they've all been excellent in every respect (I briefly had Contisports and they were horrible). I don't have noticeable side wall flex or any vagueness and I do have a very stiff setup so I'd have thought it would show up very clearly (in fact I've decided I really must stiffen the gearbox mounts as play there is very noticeable). Could it be limited to just the 16" ones that are causing trouble, and those of us that have had good results all have 17's?
The serbian made front tyres on the 944S haven't had me off the road yet, in fact they seem quite good for pottering about on these slippy roads, so what do I know [
TTM
Well-known member
ORIGINAL: Peter Empson
This is what I am beginning to think.
As far as I can gather, "Steve 944t" is one of the few here, if not the only one, who has used satisfyingly the T1R in the 225/50 245/45 16" sizes, but then he has had a set fitted all around, while Neil and I have used them only at the back.
People using 17" wheels don't seem to be affected.
mik_ok
Slimboyfat used 225/50/16F + 245/45/16R on his Turbot and I know he was happy with them too.
They grip well (surprisingly well in cold conditions for a "summer" tyre). and give progressive breakaway. There is no denying that they aren't the stiffest-sidewalled tyre on the market, so turn-in is a little vaguer than on some other performance tyres. I was more than happy to live with this as my previous front tyres (Yoko AVS) tramlined badly - sometimes dangerously - and the T1R eliminated this trait completely.
Sidewall stiffness may be the cause of the mixed feedback, and I've also seen some comments about production batch variations (although that was over a year ago). I've only every bought T1-R in full sets of 4 so the car never felt unbalanced.
Super_Marv
Admittedly, compound has a massive role to play and Toyo have probably changed the compound several times during its life.
I've always found Eagle F1s fine in the cold, and they're okay in the snow when they've got a decent compliment of tread too.
edh
- he won the BARC sprint champs (2005 I think) in my car, so I'm happy to take his word one this subject.
On my second set now - I get good grip, rarely have traction issues unless I drive stupidly. They have also seen a few trackdays, mainly wet ones. Dry trackdays I try & use my P Zero C's.
I haven't driven my car with any other tyres, but see no reason to change.
Super_Marv
If you can get the newer F1 Asymmetric tyre in your size, they're a far superior tyre in the dry, over the old GS-D3 and are still brilliant in the wet.
Think I'll be trying the Vredestein Ultrac Sessanta's next, which seem to be very highly rated. They've just started making them in the right size for my rears on my 944 S3 (255/40/R17) too.
appletonn
ORIGINAL: Super_Marv
I've got them in 18" (225 & 265 sizes) and despite a softish sidewall (which helps with their good wet grip) they are also pretty good in the dry - even on track, although I could feel the rears flexing slightly at Donington...!
I think they're great for the price too - got them from Camskill & great service.
I want to try the F1 Asymetrics next though...
berg944
I have those all round on a hard setup. I am very pleased with them.
My car is light and used to spin the rears in 5th at 70mph on just a damp road.
If you are spinning these tyres in 4th and your car is less than 400 bhp your might want to......
Check your pressures
Clean the oil off them
Drive on tarmac
Check you have not swapped the rear wheels around[
Mike[:'(]
TTM
Well-known member
Grip was actually very good, only stability was an issue.
Imagine driving in a straight line with the steering rack unbolted from the front cross member and you will get an idea of what I experienced [&:]
Seriously, so far we could reasonably say they only work if fitted all round.
berg944
I fitted the rears only first, I could not believe how this effected the steering!!!
In my case it improved. I had bad tram-lining that virtually disappeared when I changed the rear tyres.
Is it possible that they can alter the steering geometry?
That said, it would depend on the settings in the first place and could have put yours into the "very dodgy"settings area.
Just a theory, what do you think!
Mike[:'(]
TTM
Well-known member
On my set of ClubSport I have had T1S all round and they have been just as good as the F1S which I previously had all round on the D90.
Mike, what tyres were you previously running before fitting the T1R ? Which were you running at the front when you fitted the T1R at the rear ?
I really want to believe those T1R actually work, and it would be great if we could get down to a definitive conclusion such as if they work only when fitted all round (or else), as suggested all above by others!
Could it be a thing of mixing non N-rated tyres (such as the T1R) with N-rated tyres (such as the old F1S) ? [8|]
Neil Haughey
berg944
I cant remember, they were on the car when I bought it.
I can remember that I had never heard of them before so probably an obscure economy tyre.
What I did not expect when I changed the rears is that steering changed completely.
Mike[:'(]
