Short Shift again
- Thread starter skendrick
Peter Empson
Jon's site it http://www.9xx.co.uk/
I don't have experience of his one, I bought mine from type 911 before his was available and I'm very happy with it.
Best regards,
Peter.
Peter Empson
I couldn't say for definite as I didn't do the work, but my garage didn't mention (or charge me for!) any hassle. Just recently I did have a slight problem with the grub screw coming loose but as I've reused the kit a few times its not surprising really and seemed to just need a bit of thread lock to keep it there. Its been fine ever since.ORIGINAL: skendrick
Type 911 is £110, is this one easy to fit?
Best regards,
Peter.
Peter Empson
ORIGINAL: sawood12
Pete, is yours one that installs onto the gearbox itself, which I assume needs the gearbox dropping or loosening to install, or one the ones that simply replaces the gear lever?
Hi Scott,
It can be fitted without removing the gearbox, I think I had an hours labour or less to fit it originally, but I certainly wouldn't want to do it without access to ramps.
Best regards,
Peter.
skendrick
I also here a non short shift direct replacement improves the feel as well, I have about an inch of play in gear at the moment.
I've just come back from a bit of a test run with the new kit fitted and all in all a great improvement. It may need a minor adjustment which is available or it may be me that needs to get used to it. It feels just tighter with about 30% less play than a normal somewhat worn model. The shifts themselves don't feel incredibly shorter although maybe 15-20% but just more precise. Thus far I'm very happy. The test will come Sunday week at the track where it counts!
eastendr
The quick shift makes a considerable difference. Two golden rules;
1. Use a commercial grade threadlock compound or preferably wire lock
2. Lubricate the entire linkage, especially the rose joint, with motorcycle chain lube
Jon Mitchell also supplies re-engineered gear leavers (used to be on an exchange basis) that have upgraged fulcrum pins fitted and other mods. These also tighten up the gear change, especially useful in conjunction with the quick shift kit as above
Finally, there is a nylon bushing that the pivot ball at the base of the shift leaver pivots in. Very cheap (OPC) and easy to fit while you're doing the other works.
Both WUF and baby WUF are modified as above and those that have driven them will (probably) testify to how good the shift feels. I fitted the original gearbox linkage on the ground (bank holiday weekend so no ramp access, but I couldn't wait to try it), but fitting on a ramp is significantly easier. It is in the bounds of DIY
The final result makes the 944 gear change in to what it should have felt like and considerably better than my original one year old 944 did in 1984. It's not a cheap modification to go the whole way, and won't give a performance improvement, but your driving enjoyment will increase considerably.
HTH
Rick
ORIGINAL: skendrick
I spoke to Jon and he quoted me £150 for the part and 3 hours labour to fit, I now have concerns and might go with type911 for £110 and fit it myself (most probably with a lot of cursing).
Did that include a refurbed front end as well?
Tony
