Shocks!
- Thread starter dann944
ChasR
The shocks themselves I don't think you can rebuild (bar maybe the M030 suspension), but the front shocks are fitted within the strut. These shocks (which are inserts in the struts) can be replaced with a new shock put within the strut.ORIGINAL: dann944 I didnt even realise you could rebuild shocks?
It depends how old your fronts are. If they are more than 5-6 years old you will easily notice a difference when you change them for new ones (I believe your '84 car has inserts at the front so are easy and cheap). If they are more than 10 years old you will notice a HUGE difference - it will be like getting into a different car and providing everything else is good (bushes, steering, alignment etc) it will feel like Porsche intended it to when it was built.ORIGINAL: dann944 The Rears Shock on my Car are pretty worn, i looked under the car yesterday and they are very rusted too, should i change all 4 shocks?
They will have been pretty much knackered about 10 years ago. Yes they still work and yes they will pass an MOT but they are hiding a fine handling sportscar under there. Your car is possibly about to become much sweeter than you know [ORIGINAL: dann944 mine is an 87 car, i'm pretty sure there is no history of the shocks ever being changed :/
