Servotronic Problem - Help Required
Caesium
I have an issue with my servotronic and I'm looking for anyone that may have some guidance.
Having metered out the solenoid it is only showing a max 40% duty cycle at idle, which suggests that the servotronic thinks the car is moving faster than it actually is. Tried two different servotronic controllers but both stuck at 40%.
Anyone got any thoughts what the issue could be? Initially it looks like the PSM is sending an incorrect signal to the servotronic as that is what seem to dictate the level of assistance in the steering.
fnf I have an issue with my servotronic and I'm looking for anyone that may have some guidance.
If the duty cycle is stuck at 40%, it might be worth checking the signal calibration or considering whether there’s an issue with the communication between the PSM and servotronic controller. You might also want to verify if there are any errors or faults stored in the vehicle’s ECU that could be affecting the system.
In the end I just used a buck converter to buck the supply voltage from 12 to 8.7v into the actuator which made the steering feel just right, light enough for manoeuvring but not so light to put me in a ditch at speed.
I could not find the reason for the servotronic relay to be only offering 40% duty - I may investigate further now I bought an oscilloscope in the not too distant future
