After a bit of a poke around (bare hands only at this point):
Trying to find material that isn't surprisingly solid looking iron oxide/underseal composite:
The tin worms have eaten all the way though to where the exhaust back box sits:
Ouch... not got a lot to work with here. It's a lot worse than I expected... hoped it would look more like this one:
http://www.porscheclubgbforum.com/tm.asp?m=690434
There are about 4 panels that join together in this area, all of them are badly corroded in parts. Have a complete repair section from Elliot so trying to split the required repair panels out of it.
Can I lower the exhaust out of the way without unbolting flange joint for the the back section... the bolts are nicely corroded and it looks like they'll just shear off. Is there enough 'flex' in the system?
