Self Use Workshops
BL_No1
Hi all ,
I have my perfect car that I’m never selling so instead of paying for a specialist I am going to do as much work on my car as I can myself, only issue is I need to hire a worshop with a hydraulic car lift.
Does anyone know of a decent one near Leigh on Sea?
Don't know if you are still looking for a workshop or have found one -the nearest I could find is a place in Gravesend called carramphir .co.uk. It looks quite good and does have some tools available for your use.
You might want to consider investing in a set of Quickjacks as the updated versions give around 20" of lift and provide really good access to the underneath.
I have a 944 S2 and have so far removed the exhaust system, front crossmember and replaced the engine mounts, removed the transaxle and torque tube for a clutch change and everything except the torsion bar assembly of the rear suspension, front wheel hubs , front calipers, front wishbones, both front and rear anti-roll bars all with the car on a set of Quickjacks.
