Asiangunner
Thanks guys, I will check that tomorrow when i have day light.
    when teting the plugs hold them with some insulated pliers or similar against an earth point (cam cover) as they can give you a nasty jolt
ORIGINAL: tref
OK... So we believe it has a spark on all four cylinders, 3 out of four plugs look like they are running with varying degrees of richness... ignoring the "firing" noise from the engine, it sounds like it is hunting - as one would expect from a particularly rich-running engine. Have you looked at the state of the air cleaner? I suspect that isn't the problem, but it is the obvious start. After that if you can the next logical thing to do is look at the fuel pressure.
ORIGINAL: JamesO
Is your car watertight? might be worth checking the ECU (DME) hasn't got wet with all the rain we had the other month. On the early cars it's located on the drivers side near the hatch release button IIRC.
ORIGINAL: tref
Hmmm... have you done a compression test? just wondering if it could be blowing by between two and three without showing the usual head gasket failure symptoms? Although that wouldn't explain it running rich/blackened plugs... probably worth doing anyway though just because it is an easy test, and compression is fundamental to an engine running well!
ORIGINAL: tref
I would expect a variation in compression figures if it were the head gasket - unusual to get all four down, and I haven't converted it, but it sounds a pretty healthy compression figure to me...
I must admit before pulling the head my next step would be to find 4 identical sized jam-jars, pull the injector rail off, and hold it over said jam-jars, and figure out to lie to the ECU and tell it to squirt fuel in, and compare the amount of fuel going into each cylinder. This will also allow you to have a look at the spray pattern. Again, if two cylinders aren't running, this should allow you to see if it is the signal to two of the injectors"¦ even after that, I would be wondering if the barn door track is telling the ECU lies, and trying to figure out how to check that.
