Seat memory issues..!
- Thread starter James_W
If that doesn't work then try M then each of the other numbered buttons as the key may be paired with a different number. Not sure about the pairing bit but the fir M + number works on mine.
kasspa
Had same prob with mine & sorted it via online search before signing up to forum....
To clear the memory from the ignition key(s), switch on ignition with desired key then hold down the 'key' symbol button & 2 simultaneously for 5 seconds
To set memory in appropriate ignition keys, switch on ignition with desired key, adjust seat & mirrors, (if you want n/s mirror to tilt down while reversing) put into reverse gear, then hold down 'M' while pressing 'key' button.
Hope this works for you too!
To be honest I didn't really find the mirror tilting helped much.
Good Luck,
Paul
