Seat belt alarm
- Thread starter henry997
ORIGINAL: henry997
Is there any easy way to disable (the slightly sanctimonious) seat belt alarm, or at least set the limiter to chime in at a higher speed?
Get another buckle part of the belt and keep it in the slot [
ORIGINAL: camcayenne
why would you want to? Having seen the results of an RTA when airbag went off and driver had no seatbelt I can assure you its not something you want to do...
Henry doesn't want it entirely off (as far as I read) but only to wear his seat belt when the car is doing slightly more mph then the current set limit for the alarm which I think is close to 5mph(?).
ORIGINAL: Dev
yeah, i agree. setting the mph to say 10/15 would be better. it means you don;t need your belt on to keep the bepeing away when driving around in a car park looking for a space, or moving the car from the drive into the garage etc.
anyone know how to do it?
Agree. I take mine off for maoevering, which would make the exercise much more challenging if i had park sensors... bleeps going off all over the place ! [
Ronnie C
It is a simple reprog, but has to be done at an OPC (and not all will do this for you, even if you offer to sign a legal waiver).
ORIGINAL: Ronnie C
I agree that off when the car is slower than 5mph would be great; but this is not possible. The seat belt alarm can be set to on at all times or off at all times.
Thanks for the info
Nick
In a previous C4S, I sorted mine out by wiring a resistor across the disconnected connector so that it always appeared to the electronics that the seat belt was in use. Seem to remember I used a 560 ohm resistor but YMMV.
It is an all-or-nothing choice because the speed sensitive element will be implemented in software, probably by the same area that gives you the option of locking the doors when you start off.
I daresay that such a modification voids the car's type approval or some other nonsense...
