Sealing tail lights.
- Thread starter white944
pauljmcnulty
You need to get it good and hot: the bodyshops use their heat lamps to soften it in order to get a good seal. Tighten the bolts on the lamp housing evenly, and carefully.
I got what I thought was a thin profile, but still have it leaking out of the housing. Easy to trim off, and better to be over-sealed, but there must be a correct size? [
Shark
Kongsodoken
ORIGINAL: pauljmcnulty
That's the stuff. What I don't know is the right size to buy?
I got what I thought was a thin profile, but still have it leaking out of the housing. Easy to trim off, and better to be over-sealed, but there must be a correct size? []
PET says 9mm $[8|]
I hate the stuff I used neoprene foam in the end .......good job must have fitted the lights 20x [
pauljmcnulty
PET says 9mm $
I think I bought 6mm, and it still oozes out!
I guess more is better than less, as unsealed rear lights suck in fumes and water...
944Scott
ORIGINAL: Kongsodoken
PET says 9mm $[8|]
I hate the stuff I used neoprene foam in the end .......good job must have fitted the lights 20x []
Snap!
I need to take mine out again soon for more mod's.
bumperblue
Also you can get water inside the lights as well I drilled a small hole in the bottom about 2mm diameter (invisble) and that cured that problem. No idea how water gets in must be between the individual segments. I suppose after 20 odd years I would leak to!
Ian
ORIGINAL: bumperblue
Ian
A common problem of men of a certain age I understand but at 20 I think it deserves a trip to the quack [
Mick
