S2 temperature gauge is not working
- Thread starter charles.y
Sounds like you are having a rough time with the cabrio these days - accelerator cable problems and now this.
It'll be one of three things. Either the gauge is duff, the cabling is duff or the sensor is duff. And that's all the help I can add! I don't know how to test any of them without taking it apart ...
I do know that one temperature sensor is mounted in the lower part of the engine block and can be accessed from underneath the car. It is a small cylindrical thing with two wires attached, screwed into the engine (3cm diameter, perhaps, and maybe 3cm long as well.) One wire is the oil pressure sender, the other is (I think) a temperature sender. You could try seeing whether these wires are still attached ...
I'm sure someone more knowledgable will be along soon to offer some more help!
I wonder what should be the correct position of the needle when its cold so that I can attemp to secure it back. Please advice.
Charles
John Sims
PCGB Admin
ORIGINAL: charles.y
... I accidentally got the temperature gauge needle out and managed to put it back where the needle is now at 6 o'clock position when its cold and only manages to move to the 7 o'clock when the engine is hot and stuck in traffic....
Ah! If it ain't broke fix it 'till it is. [
It sounds like the needle is moving the right amount it just starts from the wrong place. (Any particular reason you put it back on at 6:00? [
