peanut
Someone on here recently suggested checking the cills by removing the plastic air grille on the inner door pillar but i cannot find the post to thank them and give them credit.
Just looked in my cills as there is a little surface rust starting to show in front of the rear wheels .
Fortunately its not too bad and the is no filla so I shall paint it with an oil and grease mix to halt any further rusting until I can get around to dealing with it later this summer. I have some rust beneath the plastic skirts as well so I'll do both at the same time.
Thanks for the suggestion whoever it was. You can see everything very clearly with a torch and access is pretty good through the hole.
