Gentlefolk...
I've not been on here for ages, come up against a problem and it would appear to be a popular topic at the moment!
At approx. 230k miles I noticed a slight hint of maionaise in the header tank... it hasn't seemed to get any worse, but obviously I have been keeping an eye on it, and the rest of the car... at 233k miles on start up I had just a hint of labouring instantaneously as I tried to start it - immediate cold sweat that it was hydraulic lock, but it cleared before I had a chance to react (I bent a con-rod on a diesel years ago in this manner, hence my paranoia)... that same day the temperature gauge started climbing higher than usual, and I fancy smoke from the exhaust. It has been switched off and I am now starting to strip it down for what I suspect to be a head gasket change.
The cam cover is off, and all looks in very good order... so a couple of questions - is it possible to lift the head with cams/chain/tensioner etc in place and without disturbing it, and how heavy is this assembly (my engine crane is miles away, but health issues mean I am limited on what I can lift)?
Any other advice? This is a high mileage abused daily driven snotter, so I am not in for a major rebuild, though how far I go in other preventative stuff (belts will be changed, water pump has another 40k miles at least, but I am now seeing some leaking around balnce shafts, so suspect I may change the top hats as they are cheap enough).
Best wishes to all in this New Year,
Tref.
Tref.
