S2 Chips
- Thread starter zcacogp
AndrewS
If anybody wants to try a 944S2 chip on the day - I'll bring along a few. No charge (unless you decide to keep it). You will notice more difference driving the car and results are varaible (due to age and wear on what is now at least a 16 year old car). A dyno run is done at full throttle - hence will not show any differences applied to the idle or 3D partial map. Peak power gains will be moderate - don't expect much more than 5 to 10bhp (we have seen higher - and lower). You can download the fitting instructions at http://www.promaxmotorsport.com/instructions/promax_performance_chip_installation_guide.pdf
It's a zero risk way of trying if interested. Further details here: http://www.promaxmotorsport.com/promaxchip.htm
Regards,
Andrew
944turboS
The change over will only take a couple of seconds on the day to move the plud over.
I still haven't had time to look at the ECU number on my S2, but hope to find 10 minutes to pull it out this weekend.
However, having eMailed Richard (EEC Tuner) of blitz chips twice over the last week, I have yet to have a reply, so am rapidly concluding that he has moved on, or gone out of business. On this basis, I would have less reservation over finding one of his chips and plugging it into an EPROM reader.
On this basis, is there going to be anyone at Silverstone who has an S2 with one of the Blitz chips installed?
xenon
I had an email the other week from Andrew at ProMax. He tells me that they acquired all of the Blitz chip coding and that's what they now sell. They have developed the maps some more themselves. Andrew is going to bring some of his chips to Silverstone - but he won't be keen on you copying them [8D]
ORIGINAL: zcacogp
Ian,
Hmmm, interesting. Thanks for letting me know.
Why Hmmmmm. interesting?
xenon
Before you all flock to your keyboards, I know why they don't do this on turbo cars, especially nowadays. Extended service intervals, sealed-for-life gearboxes, variable fuel and servicing quality across the global market, variable operating conditions and so on. For example, the twin-turbo BMW 335d can be given a massive power and torque increase with a chip - BMW don't do this because of the hammer the transmission will take and the increase in engine stress will result in higher warranty expense if every rep-mobile is tuned to the max. If you want to increase the power as an enthuisiast then you'll probably take care of it, change the oil regularly, use quality petrol, etc. etc. - even then you'll lose your warranty.
However, it's different with normally aspirated cars. Even the sellers of these chips warn you not to expect too much in terms of increased specific output, but the car will be more 'driveable'. If that's the case it begs the question why the big R&D teams at Porsche didn't do this to start with.
I can understand that the chip still may be a bit generic and can see the benefit in doing a 'live-map' on a specific vehicle, but if these after-market chips are for 'any 944S2' will it be so much better than the original? It's easy to spot gains on a turbo car because the gains can be significant, but I wonder if, on a NA car, feelings of big driveability improvements are 'auto-suggestion'?
In terms of fuel-air ratio, maximum power, best fuel economy and minimum emissions are all trade-offs. It is not possible to maximise all 3 or even any 2 simultaniously. Power peaks when the mixture is rich (lambda about 0.86), overall emissions are minimised with a stoichiometric air-fuel ratio (lambda = 1) and fuel consumption is minimised when the mixture is weak (lambda is about 1.05). Assuming the engine is delivered from the factory with the best overall compromise (with the mixture set to stoichiometric), then I can understand a re-map could yield more power but not combined with better fuel economy as they often claim.
Are these chip adverts being economical with the truth or am I missing something here?
Most of them are written with 98 RON Super Unleaded in mind so there is a small gain to be had there if the timing is set for higher octane fuel but I am willing to bet that an awful lot of people with chips still put in 95 RON
John Sims
PCGB Admin
Manufacturers chips (particularly in the International 944) have to work in all market locations/climates and with all market emission regulations. They also have to ensure that the car is drivable by Lewis Hamilton or his Granny. Granny Hamilton doesn't like cars that you have to rev to get away from the traffic lights because all of the power and torque is at 4K+. Performance tuners can throw all of those constraints out of the window.
Will an alternative chip make your car better? In certain circumstances perhaps yes. You may perhaps sacrifice cold weather starting or super hot weather reliability, or the ability to pull away on tick over, or something else. Manufacturers can test their cars in every conceivable climate and condition.....a man in a shed can't.
Ya pays ya money ya takes ya choice. [
