S2 Cab wiper mechanism
- Thread starter charles.y
If the 'balls' are ok, not pitted or to small you can rplace just the arms and you should have change
from £30.00. One is about £7.00 and the other about £15.00. If the balls are worn it is easier to replace the whole
mech. I replaced mine on the 68 (basically the same) and it was £170.00 from Porsche, I decided a 2nd
hand one would not last long anyway. It took about 2-3 hours to fit.
peanut
If you can find a way to remove and replace the spindle only then yes a new arm will work but I could not see a way of getting the wiper arm spindle out
peanut
I think I tried to centre drill the ball so I could fit a spindle bolt and lock nut but there is no access .
There might be a repair possibility by fitting something to the link-arm to replace the plastic socket which will clamp around the spindle ball rather than just a press interference fit
Charles
the spindle is bolted through the bodywork and has an angle welded to it at the bottom the other end of which has a brass ball joint .The link arm has a plastic socket which is a press fit on the ball of the spindle arm . Mmm need a decent picture really to explain this.
Tony
But it seems to me the wiper systems are different on the pre-85 and post-85 models where the pre-85 has a seperate short connecting rod '3' (on the o/s) and a different long connecting rod. This may explain why some found it easy to replace the o/s connecting rod without the need to disturb the n/s end - I think they maybe the pre-85 models.
It looks like on the post-85 models, replacing either the connecting rod or the frame will have to get under the plastic cover and discconnet both ends etc.
peanut
It ain't gonna get done from the armchair lol. We'll all be here if you need any advice half way through . Worse that can happen is it falls off again and you are £15 out of pocket and then you'll need to remove and renew the complete assembly. or you can't manage to refit the new arm and have to run it into the local garage.
Give Bert a ring or email him he can advise on part No and price of whole assembly if you go that route.
