S2 air recirc & full demist buttons
jonk
The two buttons above have worn away their graphics, but still work fine. A small issue I know, but I were to replace, do the buttons come separately or are they all part of the climate unit? This is a non a/c car....if I can replace the buttons separately I will. If it requires a new climate unit, I won't bother...!!
Thanks chaps.
Jonathan
If you want new parts I think that's a question you will probably need to ask your local OPC parts man, rather than us...
However, getting some less worn parts off a scrapper should be easy enough, or failing that reprinting the design on the old buttons is probably the sort of thing a company like this could do:
http://www.dalcoscreenprint.com/screenprint.htm
I bought a new sunroof switch a few years ago and it was about £40, so not the end of the world new. Worth a call to your local PC.
Buttons domn't come separately. I will have a look in my parts stash as I have a few units for spares if you want?
Alasdair
Hi Jonathan,
I was able to replace my fan speed knob from OPC not sure about the buttons which are likely part (top) of a push in switch which might be available? Not all parts guys at OPC's know older cars so best to ask for one who does when calling!
Hope this helps?
