Quarterflash
My car is an '89 turbo with nearly 160,000 on the clock. When it runs ok the performance is sparkling and faultless.
This is a most frustrating problem. It has similarities to other problems in that it goes away the minute it enters the Porsche garage for fixing. I have had the problem on and off for about 3 years.
The problem is one of rough running. So I can usually start the car and drive anywhere without any problems but if I stop for some reason and then subsequently start it again the engine goes very rough - as though the choke is out, if there were one. Most recently when this occurred the car got me about 4 miles and then wouldn't go above 2000 revs. The usual way to correct this phenomenon is to let the engine cool for 5, 10, 15 or 30 minutes and then it will be fine and continue as though nothing had happened.
The car has just had a full service with replacement distributor cap and rotor, a length of return fuel line replaced and all the other usual stuff. Previously we had tried replacing the throttle body/valve and MAF meter unit to no avail. It appears to come and go for no apparent reason.
It will be going back to the garage (Pro-9) for diagnostics and further investigation.
All comments would be appreciated.
