roll cage
- Thread starter Guest
CAGES EMC Motorsport are the sole UK suppliers of Safety Devices Cages for Porsche 924 944 968 911 964 and 993.
We ALWAYS have cages in stock ready for delivery - both weld in and bolt in for 924 944 and 968, plus weld in for 911, 964 and 993.
Note: look in work in progress and race car projects for photos of installed cage kits.
Neil Haughey
Big Dave
ORIGINAL: Toms968CS
Quote from website -
Tom.
Yes they are the nominated SD cage suppliers.
Yes they might well sell you one, if they have any in stock.
BUT
They dont reccomend the bolt in versions. Well they didnt to me...
Ive asked numerous times....[
Anybody that knows Kev / Alex will know what im on about....[
paulf968
tend to make Kev tad tetchy!!
............. that is because he wants all his customers to have long healthy lives and continue to spend their money at EMC - Kevin takes Safety very seriously and it is a no compromise area of his business.
EMC put the bolt SD cage in my car before my ownership, however & I can't quite work out how its got its scruitineers stamps, the A pillar mounts have no plate under them, which isnt really ideal..
asjasj
I have seen several 'professionally' welded in cages with some joints not fully welded. Worst one had some silicon sealant applied to cover the difficult to get to missed weld!!!
A bolt in cage can be installed by someone far less skilled and still be OK. Obviously the better it's fitted, the better it will be.
Dedicated full race/rally car = weld in preferred
Road/occasional trackday car = bolt in fine (rear cage only preferred as un-helmetted heads and front roll cages don't mix well)
EMC would only sell full cage.
If you explain to Safety devices you only want half cage (bolt in), they should help you out, they did with me!
I rallied a SD1 rover for years with a bolt in full cage including removable diagonal. As previously stated as long a spreader plates are installed correctly and the correct spec of bolts used then there will not be a problem. Not quite as strong as weld in but not as big a diffirence as you might think.
lali
...oh wait no... I'm lying [
You can buy a weld in cage and only have half of it fitted.... but yes it does mean that you compromise your cars usage.
personally I would trust anything that bolts into the seatbelt mountings.
My brother had a very nice bolt in half cage from roll centre, they even added an additional short horizontal for the harnesses.
