Roll Cage Wanted
- Thread starter 944 man
chrisg
Having just got back from the Ring, I've decided to take the plunge and fit a bolt-in cage for safety. Anyone know of a second hand available or failing that recommend a good supplier ?
I have on-hand my brother who is handy at welding so installation and fitment isn't an issue.
Yours
Chris
CarreraRSR
Thats true. Kev refused to fit a bolt in cage in to mine, but also didn't want to weld one in as mines a street car first and didn't want to ruin it. Suggested Roll Centre as the place to go for a bolt in. Finalising a buy [link=http://www.porsche924.co.uk/forum/viewtopic.php?f=14&t=5908&start=20]here[/link]ORIGINAL: 944 man They should be the only supplier in the UK. The SD cage is a good deal better, but its a damned sight dearer. That said; Kev isnt enthusiastic about any bolt in cage.
edh
chrisg
edh
chrisg
edh
chrisg
Yeah I was looking at those as an option - they're (for my budget) quite pricey at ~ £500 for a set.I'd have thought you could pick up a set of S2 wheels (7 and 8) quite cheaply. I reckon £100-150 per set if you don't mind them being a bit tatty. Keep the 8's & sell the 4 x 7's to a 924/924S or 944 2.5 driver. AFAIK all the 7" D90 wheels were 52.3 offset I already have a pair of 8" rear D90's with Yoko S306's on. and a pair of Teledial 7" ET55 ones for the front. I've now got 1 x 7" D90 for the front (actually a 964 part) and about to get another one. Your clubsport wheels would sell for good money as well. I don't think failure is a big issue (I was there when Kurt's went) if the wheels are original & have not been refurbed. Did you see the pics on here recently of the ones where the front faces had been worn flat? Fair comment, but for somewhere like the ring or spa I don't want to risk it either the car spinning off or not having a wheel to get home on ! I was there when Kurt broke his and ended up lending him one of mine to get home with !. I have thought about selling mine and just running the car on D90's for Road and track usage. I was very happy with 225/50 all round with p zero C's - the balance was very nice and I had loads of grip. You may get more traction issues with a road tyre like the T1-R Maybe the V70a is a good option - Craig had those on his 328. Depends on how much wet weather use you are planning...
CarreraRSR
Any pics of the install?ORIGINAL: rickware I have a roll centre cage and it's easily fitted but if you have a sunroof you need to either cut the roof lining or fit some spacers on the hoop as it needs to go further forward than it is was designed to. very cheap though I paid £350 for mine
CarreraRSR
