resync key
fireman
hi folks, have just got my key back after repairs , how do i resync key to my 911 carrera, i see so many different ways on forums, so far none work. key had gone thru washing machine. regards to all
Without meaning to be negative, it's probably for the bin.
Transponder chip is ok i take it?
I mean it still passes immobilizer
Elwyn,
Assuming the battery in the remote is OK then I think the synchronisation procedure is:
  • Unlock the driver's door with the key;
  • Open the door and insert the key in the ignition within 10 secs (not sure if it's necessary to turn on the ignition?);
  • Press and hold the central locking button on the remote control for about 5 secs.
If that doesn't work I think you'll probably have to take it to your local Porsche Centre - or an Independent with a Porsche diagnostic tester - so that it can be recoded.
thanks for reply, have had refurb key checked and is sending signal, light on fob working, light on dash flashing, 2nd key which was working now not, also sending signal and flashing. checked all fuses, all ok, have tried all fixs on internet, no avail, doing my head in. alarm working. regards elwyn
I think it's time to get some professional help Elwyn..!
A diagnostic check should indicate whether or not the appropriate electronic module or circuitry is functioning correctly.
thanks for input, i have guy calling at weekend who is key, electronic boffin, so shall see if he can sort problem,let you know outcome, regards elwyn
