Removing Brake Calipers
I'm trying to remove the front left brake caliper in order to replace the wheel bearing - however, I can't get the caliper mounting bolts to shift. They don't by any chance screw in the opposite direction do they? I have tried everything at my disposal to get them off, but they won't budge - any suggestions? This is so annoying as otherwise I'm going to have to take it to a garage to do a job that is otherwise nominally fairly straightforward.
Cheers,
Graham
No they're normal thread.
Had my passenger side front off this morning to try to cure a slight judder that's recently started.Turns out both screws holding the disc were loose and the inner pad was stuck firm.I'm going to give the drivers side a check too this afternoon.
The bolts are tight tho' - i had to use a couple of whacks with a mallet to assist as i couldn't get enough pressure on them with just my adjustable socket.
Some people seem to apply locktight to caliper bolts for some reason that completely and utterly bemuses me. It could be that. Recently I replaced the pads and discs all round on a friends 306GTI6 and all the bolts were locktighted. I have a two to three foot length of scaffolding tubing that comes in handy on occasions like this.
I took the car to a local tyre fitter who put the car up on a ramp, undid them (to get them started) did them up again, and after a careful drive home I was able to get them off with my socket set.
YUP
Locktite 242 every time. They get hot and cold and hot and cold etc etc and I never want them to come loose.
I may be wrong but if I`ve rebuilt the car (and I`ve built a few) and I`m carrying other people and therefore responsible for their well being then I`m afraid I`m a belts and braces man [8|] Loctite doesnt affect the torque figures either.
If I`m wrong then let me know.
After checking both my front calipers today I i'll be putting locktite on the two screws that hold the discs on this week - all 4 were loose causing judder/movement.I can't believe that only 2 half inch or so long screws is all that secures the disc (bar the actual caliper).They were only skimmed in march for the MOT too.
ORIGINAL: Hilux
If you want more torque, turn the boost up [:D] [:D] [:D] [:D] [:D]
Sorry, I know that wasn't very helpful [:)]
Rick.
ORIGINAL: 944cabby
Is there not a small matter of 5 flaming great lug nuts??? The small screws only position the disc - they play virtually no part in securing it.
Dave
That's what I was going to say - I have run an S2 without the screws for a while as I forgot to buy them and changed the disks on a Bank Holiday weekend.
Well, I've managed to get the caliper off (basically, in the absence of an air gun or a 20" breaker bar, I used a bar from my socket set and kept on braying it until they started to shift!). Now my problem is, does anyone have any handy hints for getting the bearing races out? Clarks garage talks of tapping the bearing races out of the hub. Admittedly I've been using a flat-headed screwdriver, rather than a round tipped punch (since I don't have one) but tapping has produced no movement, neither has a prolonged period of belting either - any suggestions?
Cheers,
Graham
I think you may need to apply heat in that case.
If you're lucky, Jon Mitchell might see this thread and offer some professional advice.
Rick
If I were you I would still buy yourself a long breaker bar (30inch) I find it will always be handy for some other bolt or nut somewhere.
ORIGINAL: GCHinton
Cheers,
Graham
Put it in the oven for about 30 minutes at what ever temp clarkes recommend, remember its F and most ovens are degrees C. Stand in a tinfoil lined tray to keep the ovens main user happy (or wait till they go out), then using thick gloves remove it and tap out the race. Reheat to install the new ones.
Tony
Surely thats only if you use 'self raising' bearings ? [:D]
Tony, Mags wants to know if you've got any other 944 recipies ?
[:D] [:D] [:D]
Rick.
ORIGINAL: 944Turbo
Tony
Now don't tell me - I think I know where the oven is - I think that it is in the same strange room (I think it may be called a 'kitchen') that the machine washer is kept and the tumble drier. However, as I understand it the machine washer isn't big enough to get any reasonable machines in, and also I don't have any tumbles that I need drying, so previously I haven't had too much interest in that room (except the beer drawer in the fridge).
Cheers,
Graham
ORIGINAL: 944cabby
DON'T DO IT!!! On a previous car I've been in the position where those screws have been either overtightened or blasted loctighted in and stripped the philips head. These screws are rarely made from a decent high strength steel and the head can easily be stripped as they are purely used to locate the disk when the wheel is off as other people have already said. I ended up having to drill off the countersunk head - a major pain in the butt.
I'd be very suprised if the two locating bolts being lose was causing judder unless it was their lose presence that was causing it. Quite a few cars don't do locating screws, and the discs are lose as soon as you remove the wheel nuts (Audi and VW spring to mind).
It's a pain without them though - the discs always seen to turn half a thredhole!
ORIGINAL: sawood12
ORIGINAL: 944cabby
Well, had a couple of runs and the judder has gone so i'll leave well alone now.It was definately either the pad or the screws.I'll see if it returns then check them again otherwise it's another problem sorted.
