Relay and fuse layout for a 83 944
- Thread starter tandy
Amything else, I may be able to help with.
Mike
Northern924
Oh and the fuse is on the Aux board under the glove box
Intermittant wiper is the one just above fuses 9 and 10, but I've no idea about the rear wiper.
Mike
Should work - crossing fingers and thumbs etc!
The relays are i think standard types - check the numbers by the pins carefully - but the ones on the tranny tunnel have clips attached which are unusual but if the numbers are ok then I would make my own mounting.
Mike
ORIGINAL: A9XXC
what I want to know is, should the windows work with no key in the ignition and the doors open? mine do and I'm not sure they should!
Yes they should.
I have seen all sorts of bodges on early 944 windows... many of which stem from the connection in the drivers side pillar not being polarised. if they are put back together the wrong way round, the drivers window will work perfectly, but the passenger window ceases to function. the problem, of course, is that people immediately think it a passenger door problem, and even looking at the switches it doesn't point to this connector as being a problem...
My problem is that both windows work fine with a replacement relay, with the ignition on as usual but also work regardless of ignition switch position IF either dor is open - ie interior light is on.
Am I normal?
Mike
ORIGINAL: A9XXC
Am I normal?
Mike
Correct. This is how it should function - it is mentioned as such in the owners handbook for eth car - a feature incorporated so that if you get out of the car without closing the windows, you don't have to put the key back in the ignition to close them. Once you know the feature is there it is surprising how often you use it!
And yes I 've used it twice today (never before).
Tandy - Unfortunatly, I have 2 halves of the centre cap!
Mike
Edit - A bottle of Shiraz does wonders for ones spelling etc!
