Red Master Key?
- Thread starter harvey
leesweeney
ORIGINAL: harvey
I am looking at a 2 owner 1995 car that doesn't have a red master key. Should it have had one in addition to the two black keys? Many thanks, Harvey
I imagine so, my 1997 'S' has the red master key and a mate of mine's turbo, which I think is a 95 car has a red master key so I guess you probably should Local independant or OPC should help though and I know you can get them retrospectively (I know someone who did).
2 owner car from 95 sounds promising!
ORIGINAL: ian_uk
If it's a PA1000 alarm then it should have a red master key. If it's a PA2000 alarm then no red master key.
Ian.
Thanks Ian, straight forward, simple facts, I like it
My '95 C4 Cab had no red key and has PA2000 alarm
38F3E1
What you are describing sounds like the previous Porsche system which was fitted to the 964. This was a CAT 2 immobiliser only which has a little piece you insert into the slot in dash or consol.
So the car could have just an immobiliser (Porsche or aftermarket) or maybe an immobiliser plus a third party alarm (as there would be no need to have the slot with a PA1000 or PA2000 alarm).
Ian.
I think the early 993s got the old system from the 964 so I stand corrected on my earlier post.
my cab has the little dongle tag thing too plus a switch in the centre bottom row of the console in front of the handbreak. I believe this switch disables the microwave sensors for the alarm mounted in the corners of the dash as it also allows you to lock the car without the roof auto closing.
My fob only has one button and looks fairly generic, there is also no mention of an alarm system in my option codes. So I wonder if the dealers were retro fitting their own systems back then?
Harvey, are you going to buy the car???
Michael Williams
A 1995 car may well have the PA100 alarm system (single button handsets, marked PA100) AND the immobiliser dongle (as with my TT). To get a replacement red master, you either have to replace or reprogramme your exsiting alarm control unit. Both of these options are still available from Hamilton & Palmer (who made and supplied them) at a very reasonable price. The job istelf is very straightforward as the unit (located under the drivers seat) simply plugs in to the cars wiring loom. No need to go to an OPC / specialist, I would say.
H&P are very friendly to deal with and provide a very prompt service. They told me that this system has proved very reliable in practice, but a fair few of us are coming to them to sort out the ubiquitous missing-red-master problem!!
good luck
tim
Best option of all though has to be to track down the previous owner who still has it!!!
38F3E1
But why unless the PA1000 was retro-fitted at a later date? I can't believe this is how it would have come supplied from an OPC because the PA1000 system contains an immobiliser plus positive locking plus alarm therefore the dongle immobiliser would be redundant.ORIGINAL: tim993
A 1995 car may well have the PA100 alarm system (single button handsets, marked PA100) AND the immobiliser dongle (as with my TT)....
Unless you really mean PA100 rather than PA1000 and we are talking about different systems.
Ian.
