Rear tyres
- Thread starter andyjwhit
chriscoates81
I'm sure I read that a 996 can have dodgy wear if you don't corner hard enough.ORIGINAL: carnaby35 996 c4 with MO30 suspension. Just about to change my Michelin Pilot Sports after about 12 k miles. They wear a lot on the inner edge due to camber so I changed them round on the rims to put the bald part to the outside and the good part to the inside. ( I am tight) Got some new Michelin PS for £600 for the pair but they are now an asymmetric pattern so won't be able to swap them on the rims when worn.[] cheers, chris
^^^^^ +1 If they are wearing unevenly, then get an alignment check done. I used to get 12,000 from the rears (Pirelli and Michelin) on my C2, and the wear was perfectly even across the tread. There were several reports of Contis lasting only about 4000 miles (me included, on my Turbo) but I think that iit is resolved now.ORIGINAL: AlexBell I'd be looking into a new alignment if I were you, my Michelins usually lasts between 12 and 15 000, and after I did the last alignment the inner wear got much better, even though I've got max camber.
andyjwhit
We're talking 285/30/18? See here...........for N3 tyres http://www.tyres-pneus-online.co.uk/car-tyres-285-30-18.html £209 delivered - add £15 for valve/balancing if you have a friendly tyre place near you
