The cab drains through 2 holes either side at the front corners under the boot lid. if you look you will find grommets there that will have dried out letting the water in, a common problem on them. Get a small bit of tigerseal or similar and seal them with that. Also check the petrol cap drain for the same thing,
Alasdair
Alasdair
