Rear seat cushion removal on 970 Panamera
DoctorMesmer
I’m trying to remove the rear seat cushions on my newly acquired 970.
I see lots of posts with others finding it impossible. I’ve seen the diagram where it tells you to press a screwdriver against a tab to release it, but I’m no further forward.
Has anyone managed to do this and, if so, what’s the trick?
Thanks in advance for replies.
Hi, my local specialist ended up breaking all the plastic clips to get the squabs out. Replacement clips are not too expensive, I vaguely recall they are abut £5 each. I'm planning to remove the squab over the weekend and reading up, it says grab one side and pull sharply up. I'll be giving that a go. Hope this helps
Oh, and congratulations on the 970. Ive had mine a year and the car has challenged me at times so I have and still am, learning a lot about it. Give me a shout if I can help in any way, happy to share my experience if it will help others.
Thanks for that! I should add that my rear seats are optioned as:
833 PREM. REAR SEATS (40/20/40) SPORT
943 REAR SEAT COVERS, LLL (ALL-LEATHER, PLAIN)
so I’m wondering if there’s something different about the cushions from standard seats (maybe welded in place?! ;)).
Hi, it does feel like they are welded in but you should feel some movement when you try and lift the squab up. The plastic clips are incredibly hard. So pull up one side upwards as hard as you can. Failing that, you will have to brake the tab that locks the clip into the metal below the seat. See pic.
The replacement clips a £4 each.
Good luck
That’s very helpful – many thanks! That will be my next mini project over the next day or two.
Will let you know how I get on.
Hi, the only option now is to place a strong screwdriver against the top part of the plastic, hit the screwdriver with a hammer and break the plastic. Then it will com out. I will be doing the same as one of mine is a bit loose and squeaking!!!
They are cheap to replace to hit away
Thanks, but I can’t even get the cushion up far enough to see the plastic – they’re in that tight.
Mine also seem to go into metal bracket that sits proud of the body under the cushion. Is that normal?
Hi, yes that’s normal. You could try levering the plastic up from the metal bracket, otherwise break the black plastic where you can see it. The plastic is Very Hard.
