i noticed today my near side rear light not working. changed bulb ,still no good ,swapped light cluster from offside ,no good so i think i may have a fuse blown but cant find a reference in the fuse book to tell me which one powers the rear near side light. any help greatly appreciated . cheers, Andy Mac
Rear light problem
- Thread starter andy mac
Andy,
You might need to clarify your issue...
a) Swappig the bulb seems obvious, you should remove the rear light cluster and replace with a new bulb. In most cases you can see the damaged filament in a broken bulb.
b) You cannot swap the offside -> nearside light they wont fit. However if you mean you swapped the bulbs, your less likely to be looking at afuse issue... I believe they are connectedto the same fuse - Therefore ALL rear lights would fail.
Try this. Pull the nearside rear cluster out, and check the pins, on a) the multiplug - Left in car b) the socket - on the light unit.
If you cannot see an issue, you'll need to check the feeds to eliminate the actual cluster - You will need a multimeter to do this however...
JCB..
Non-member
ORIGINAL: andy mac
Problem sorted. It was only a fuse in the end. The fuse for the rear light is marked side light left.there is a fuse for lights left and lights right . I was expecting to find lights front and lights rear fuses.Thankyou for your input gents. Kind regards Andy Mac
Thank you for the update and well done. [
I hate electrical faults on cars! [&:]
