Has anyone else experienced this problem and, perhaps, has a fix? First it was the nearside rear door not unlocking from the key fob, having to be opened from the inside, but once opened would open from the outside until locked from the key fob again. OPC fix was around £600, so now I have the same issue on the rear offside door and looking for an alternative solution before going to OPC. Is this a commmon fault?
Rear Door Locks not Unlocking Cayenne 958.2
- Thread starter RGL55
Think thats a VW part number - you should be able to find the OSR equivalent from the online part diagrams ( https://www.porsche.com/uk/accessoriesandservice/classic/originalpartscatalogue/ ) - I guess an indy labour rate would be considerably less - even if you went for an original new part ( 10% off with club discount).
JHMotorsport
Yes this appears to be a common issue and it is the door lock actuator/door lock module that fails to work properly.
We’ve had both rear (left door and right door) lock modules fail in different ways in the past. One was not able to opened from outside handle when unlocking the car, but then the outside handle typically starts working once the inside handle is used once.. until next time the car is locked and the process repeats.
I’ve fixed myself with new part and found many options of the part for between £20 up to £250 for a ‘Porsche branded’ item. We all know Porsche do not make door locks so I went for one of the mid range non-Porsche branded items.
The labour is quite significant because if your being careful i would describe it as fiddly. There are YouTube videos and guides out there on the process but none that I found made it that easy.
I think it took a couple of hours minimum and the need to be delicate with the metal cable connection.
Example part link is here below, it’s a shared VW group part and I purchased from autodoc as they had best selection.
spareto.co.uk
V10-85-0029 - Door Lock
V10-85-0029 - Door Lock manufactured by VEMO. Order VEMO door lock online and find many other parts and accessories that fit your car, bike or truck.
Thanks for the response. Yes, mine is the can't open from the outside issue on the rear offside door, it happened about a year ago on the nearside one, so clearly a Cayenne 'feature'! I won't try and do it myself but will use a local specialist rather than the OPC due to cost.
JHMotorsport
Yes there are plenty Audi Q7’s and VW Touareg’s with the same issue and part, so a job for any decent garage.
Greenman986S
And it has passed MoTs?Yes, I've put up with the same problem for years now!
