clyde
I have a split outer CV boot on the off-side of my C4 that needs replacing. Looking at the electronic workshop manual suggests that the drive shaft has to be completely removed to allow this to be done. Removal is a major task from what I can make out. I don't want to go down this route, not least because I intend to replace the suspension in a few months time and everything will have to come apart then.
From a not too detailed look underneath it would appear that if I disconnect the inner CV joint I will be able to drop it to remove the inner joint from the drive shaft then feed both inner and outer boots off and replace them both. Can anyone confirm that this is possible or is there not enough movement in the outer CV joint to allow the inner one to clear the transmission flange?
