Rear Brake Caliper Bolts Size
Beetlebum
Hello have a 2005 955 3.2 V6, changing discs on the rear, calliper bolts are they M triple square or equivalent to a T60 my T50 no good and has less/larger spacing splines also
thanks 🙏
I believe the rear calliper mounting bolts on the Cayenne require a 16mm XZN Triple Square tool.
Regards,
Clive
You're welcome. 👍🏼
The Cayenne uses this type of fastener for brake callipers because the bolts require very high torque and the XZN configuration distributes load evenly across its 12 faces, thus preventing cam‑out (slipping) and allowing the bolt to be torqued and re‑torqued without damage.
Regards,
Clive
Interesting. Some older models use T55 Torx too. Clearly some discrepancies here Unfortunately I don't have a Cayenne to check, but here's what AI has gleaned for what it's worth!
🧰 Summary table​
LocationCorrect toolEvidence
Rear Cayenne calliper mounting bolts16 mm XZN (Triple‑Square)Listed explicitly for Porsche Cayenne rear callipers by tool manufacturers.
Front Cayenne calliper bolts (for reference)16 mm XZN also appears in front‑caliper tool listsPelican Parts lists a 16 mm XZN driver in the toolset for Cayenne calliper work.
Regards,
Clive
