Re map?
- Thread starter liam996
chriscoates81
How long do they typically last?ORIGINAL: NXI20
Remapping a standard NA car is a waste of money IMO. How are your cats? When they start to break up they can block the exhaust.
ORIGINAL: liam996
Cats are brand new, well 600 miles new.
Have you performed a forced adaptation?
With a cold engine, turn the ignition on but do not start the car or touch the throttle & leave on for 1 minute. Turn off & turn ignition on for at least 10 seconds & then start. Go for a decent length drive over a mix of roads.
ORIGINAL: chriscoates81
Very dependant on how the car is driven. Short journeys on cold cats are a good way of killing them. My old C4 was still on its original ones when I sold it at 65K miles. My GT3 had melted its original ones by 45K miles but the replacements are still good and the car is on 90K miles now. It's probably done about 70 trackdays on the second set of cats.
Mine (2004 996 C2 40th Anniversary) was re-set for the first time in my ownership during the 48,000 mile service & I wondered initially where the very significant additional performance had come from - the difference was really marked !
It was only after a lot of forum searching I realised what had happened & now make a regular habit of re-setting it.
Paul
For early cars with mechanical throttle (DME5.2.2) you have to disconnect the battery for a few seonds. If you do this on an early car, make sure you have the radio code, and switch the ignition to position 1 before disconnecting, or the alarm siren will go off.
You have 7.8. Just follow the instructions. Just need to wait for a day when it is 10C............
