Radio reception
- Thread starter Alexw
I've just replaced our 10 year old head unit and CD changer with a spanking new version that plays MP3's has a USB socket and is Ipod compatible. It was a straight forward install as the old one already had the plug n play ISO cable connectors.
Problem is that radio reception on the new one is abysmal. I can pick up one very local FM stattion and no AM stations at all [&:] Swapping back to the old head unit brings back dozens of stations so it's not a problem with the antenna and amplifier to my way of thinking. Plug in the new one again and just one FM station.
I'm thinking the new one is already broken in some way, but before I return it any other ideas?
sawood12
mr brightside
The functions that make it biased towards stronger signals are LOC (local), and REG (regional). Try activating TA (traffic announcements) and see if the signal is still weak as it cuts to various stations it chooses itself, if the signal is good the unit needs setting up somehow.ORIGINAL: 944 man Paul; have you RTFM? Perhaps theres a 'local stations' option in the menus causing weaker signals to be disregarded?
mr brightside
ikillcopiers
