No! Did not shed any blood but sweat, tears and alot of swearing! Which joker thought it was a good idea to put the switch there!!!
 Anyway, I shall begin. Bought my switch from Porsch-Apart which came the following day. Cost £18.80 with vat and delivery. Didn't get round to doing it till today, Monday.
 After purchasing my de-ionised water and anti-freeze I began.
 Stuck it on some ramps and took off the two undertrays to drain coolant. As at the moment  I don't have a manual, I could not for the life of me find the drain! I also thought I might be able to get to the switch easier from underneath, but no way! So, I nearly gave up. After rubbing dirt off a screw head (blending it in with the rest of the shrapnel) I discovered it! One turn and the head snapped off! Second time I nearly gave up.
 Biting the bullet, a quick drill and stud extractor later I got covered in coolant. So, that drained I had to remove a rad hose and the airflow box to get anwhere near to get a hand to the switch. The nut is 30mm, but you would need a long socket except there is no room to get one round it or to ratchet it. Third time etc. etc.....
 Took a small adjustable, got it on the flat of the socket and thought **** it and give it a turn. Low and behold it gave, turned the rest by hand. Put new one in, replaced fuses and fans stayed off.
 Turned and threaded a piece of nylon to replace the broken bolt. Bit of silicon round it, replaced it and left it to gel a bit.
 Stuck it all back together, stuck the coolant in. Seems ok. Temp might be tiny, tiny bit higher, but his maybe I was looking at it constantly and not the usual glance. Didn't notice fans coming on but this maybe due to a new efficient switch and not coming on prematurely (ok I could be kidding myself) but I took it for a run (remember I live in London so a run means sitting in traffic) a few quick bursts when I could, and it didn't overheat and doesn't climb over the quarter mark.
 So, I'll give it another run tomorrow but hopefully it's sorted.
 Red circle shows switch position
