Question re Oil Pump
- Thread starter Frenchy
robwright
chrisg
spot on with his description and opinion = IMHO unlikely to be the pump itself. Things to look at:
1. Oil level/ volume this will help confirm if its a pressure issue or whether you've lost oil
2. Pipes to and from and the oil cooler - very likely culprit for oil loss, leading to low pressure - ask Oli !
3. Oil pressure relief valve and the oil filter/ thermostat housing.
4. Good look over the engine and engine bay to confirm/ check whether oil has been lost
Chris
I have just done 1300 miles to Germany and the oil pressure was slightly down on normal, pulled the car out of the garage today and went to move another car, walked back to it and it sounded very tappety, noticed the oil pressure lights on and next to no oil pressure [
Moved the car back and saw the crank pulley bolt lying on the drive, knocked the car off and will be underneath tomorrow with loctite and a torque wrench.
I had changed the belts before Germany and nipped up the bottom bol,t obviously not enough !
Someone from up above must have been smiling on me as if the bolt had let go when "travelling" who knows, hopefully no damage done it was all top end noise and it did not run for long.
robwright
DC911SC
Ps if there is any damage to it I have a clean S2 crankshaft pulley for not much!
